Samsung Galaxy Tab 3 as compared to Samsung Galaxy Tab 4
What are the distinct features of Samsung Galaxy Tab 3 as compared to Samsung Galaxy Tab 4? What was the concept behind the development of these two tablets by Samsung? Are there any common features that make these two tablets so special from all other Samsung Smartphones and Tablets? Which of these two would you recommend for me in this recent times if I am to pick one?
Answered By 590495 points N/A #148862
The Samsung Galaxy Tab 3 7.0 can be used for voice calls, SMS, and MMS. It is a 4G device that supports 2G, 3G, and 4G bands using GSM, HSPA, and LTE technologies. It was unveiled on April 2013 and released on July 2013. It measures 188 x 111.1 x 9.9 millimeters and weighs 306 grams. It uses a SIM card.
It has a TFT capacitive touchscreen display with 16M colors at 600 x 1024 pixels screen resolution. It supports multi-touch with TouchWiz UX UI. It runs on Android 4.1.2 Jelly Bean powered by Marvell PXA986 chipset, dual core 1.2 GHz Cortex-A9 processor, and PowerVR SGX540 GPU. It supports microSD expandable up to 64 GB. It runs on 1 GB RAM with internal storage available in capacities: 8 GB, and 16 GB.
The primary camera supports 3.15 megapixels at 2048 x 1536 pixels with autofocus. The camera supports geo-tagging. The camera can record video in 720p at 30 fps. The secondary camera supports 1.3 megapixels. It has Bluetooth 3.0 with A2DP; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, DLNA, and hotspot; GPS with A-GPS, and GLONASS; USB 2.0 (TV-out). It has built-in accelerometer, proximity, gyro, and compass sensors.
The pre-installed browser supports HTML5. It doesn’t support Java. It runs on Non-removable Li-Ion 4000 mAh battery with talk time up to 8 hours via multimedia.
The Samsung Galaxy Tab 4 7.0 can’t be used for calls, SMS, or MMS because the device doesn’t have a cellular connectivity. It was unveiled on April 2014 and released on May 2014. It measures 186.9 x 107.9 x 9 millimeters and weighs 276 grams. It doesn’t use a SIM card. It has a TFT capacitive touchscreen display with 16M colors at 800 x 1280 pixels screen resolution.
It supports multi-touch with TouchWiz UX UI. It runs on Android 4.4.2 KitKat powered by Marvell PXA1088 chipset, and quad core 1.2 GHz processor. It supports microSD expandable up to 32 GB. It runs on 1.5 GB RAM with internal storage available in capacities: 8 GB, and 16 GB. The primary camera supports 3.15 megapixels at 2048 x 1536 pixels. The camera supports geo-tagging.
The camera can record video in 720p at 30 fps. The secondary camera supports 1.3 megapixels. It has Bluetooth 4.0 with A2DP; GPS with GLONASS; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, and hotspot; and microUSB 2.0. It has built-in accelerometer sensor. The pre-installed browser supports HTML5. It doesn’t support Java. It runs on Non-removable Li-Po 4000 mAh battery with talk time up to 10 hours via multimedia.
