Samsung Galaxy Tab 7 7 ?
New improvised Samsung galaxy tab 7.7 has been launched into the market. I want to know what additional things they have added into the new tablet. Please explain clearly.
Hi, the new Galaxy 7.7 is now handy with light weight which is12.1 oz and with 39’ thin. It has they so called the Media hub where you can access lots of movies and TV shows. It also has a memory slot where you can change memory up to 32GB. It has long battery life and a more powerful with 1.2GHz dual core processor. You can also watch TV through your tab by the use of Allshare so that you can wirelessly stream from your tab to your TV anywhere in the house.
The Samsung P6800 Galaxy Tab 7.7 tablet supports GSM voice communication, SMS, and MMS. It is a 3G device operating on 2G and 3G bands using GSM and HSPA technologies. The tablet was announced to the public on September 2011 and released on December 2011 and is currently available. It measures 196.7 x 133 x 7.9 millimeters and weighs 340 grams.
It uses a mini-SIM card. It has a Super AMOLED Plus capacitive touchscreen display with 16M colors at 800 x 1280 pixels screen resolution. It supports multi-touch with TouchWiz UX UI. It runs on Android 3.2 Honeycomb powered by Exynos chipset, Dual Core 1.4 GHz Cortex-A9 processor, and Mali-400 GPU. It supports microSD expandable up to 32 GB. It runs on 1 GB RAM with internal storage available in the following capacities: 16 GB, 32 GB, and 64 GB.
The primary camera supports 3.15 megapixels at 2048 x 1536 pixels with LED flash and autofocus. The camera features geo-tagging. It can record video in 720p at 30 fps. The secondary camera supports 2 megapixels. It has Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, and hotspot; Bluetooth 3.0 with A2DP; GPS with A-GPS; and USB 2.0 (TV-out) with USB Host.
The Samsung P6800 Galaxy Tab 7.7 tablet has built-in accelerometer, gyro, compass, and proximity sensors. The pre-installed web browser supports HTML with Adobe Flash. It supports Java. It runs on non-removable Li-Po 5100 mAh battery with standby time up to 1,200 hours on 2G and 1,100 hours on 3G. Talk time is around 34 hours 10 minutes on 2G and 20 hours on 3G.
