The Samsung Galaxy Tab Camera Problems
I can’t use the front camera of my Samsung Galaxy Tab 10.1. I tried using it for Skype and Google Talk, but the thing just won’t work. What is the solution to this?
Well,Â
The Samsung Galaxy Tab 10.1 P7510 tablet doesn’t support cellular connectivity and cannot be used for GSM voice communication, SMS, and MMS. It is also known in Germany as Samsung Galaxy Tab 10.1N P7511. The Samsung Galaxy Tab 10.1 P7510 tablet was announced to the public on March 2011 and released on July 2011. Unfortunately, this tablet has been discontinued.
It measures 256.7 x 175.3 x 8.6 millimeters and weighs 560 grams. It doesn’t support SIM card. It has PLS TFT capacitive touchscreen display with 16M colors at 800 x 1280 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass featuring TouchWiz UX UI.
It runs on Android 3.0 Honeycomb upgradable to Android 4.0 Ice Cream Sandwich powered by NVIDIA Tegra 2 T20 chipset, Dual Core 1.0 GHz Cortex-A9 processor, and ULP GeForce GPU. MicroSD is also not supported. It runs on 1 GB RAM with internal storage available in the following capacities: 16 GB, 32 GB, and 64 GB. The primary camera supports 3.15 megapixels with LED flash and autofocus support.
The primary camera features geo-tagging and can record video in 720p. The secondary camera supports 2 megapixels. It has 3.5-millimeter jack; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, and hotspot support; Bluetooth 3.0 with A2DP support; GPS; and USB 2.0. It doesn’t support stereo FM radio. It has built-in accelerometer, compass, and gyro sensors. The pre-installed web browser supports HTML with Adobe Flash support.
It supports Java via Java MIDP emulator. It runs on non-removable Li-Po 7000 mAh battery with talk time up to 9 hours via multimedia. It is available in Black color. If you’re having a problem using the front camera with either Google Talk or Skype, try to check if the camera is working. Close Skype or Google Talk if it is running then start the camera.
Try taking a few pictures or record a very short video to see if it is working. If there’s no problem with the camera, try updating Skype and Google Talk. For Google Talk, download Hangouts on Google Play. For Skype, download Skype on Google Play.
