How to connect my Samsung galaxy tab WiFi USB to the internet using a USB stick, without having WiFi at home.
I am having a USB Modem with Internet connection and an adapter for tablet, is it possible to connect my tablet with USB Internet,
Please do let me know the process.
Samsung Galaxy tab wifi usb
Hi Angelaeabram,
                        It is too easy to connect a USB Internet dongle to a galaxy tab for this you need a micro USB to USB converter. Once you connected your Internet dongle through this cable it will detect by your tablet and the led light will blink on the dongle, now your hardware is ready. Now you have to configure the settings in your tablet. For this follow these steps, Go to settings in settings if you are using 3G network then check the box 3G, now select mobile network settings in this put a checkmark in data enabled, data roaming and select use only 2G network if you connecting a 2G connection, Now click on data access points on the screen your data card or Network service provider name will be appear for example : Reliance, Tata Indicom, Airtel etc. that’s it once your LED light in dongle glows continuously than your connection is established with the network you can enjoy the Internet.
