jonjessph
30 points
Posted on - 06/18/2012
Samsung had just introduced the Series 9 900X3B, a laptop update. What are its characteristics in terms of thinness and booting up time which make it a darling of the laptop consumer next to the Apple MacBook Air?
Samsung laptop a close second to Apple’s MacBookAir
Samsung's 900X3B and MacBook Air laptops are very thin light weight devices, but the thinnest one is Samsung Series 9. The MacBook Air 13in brandishes a most extreme thickness of 17mm, but Samsung's 900X3B takes slenderness to unique levels, measuring an insignificant 12.9mm at its bulkiest finish.
When it approaches weight the Series 9 wins, as it beats the Air's 1.35kg by tipping the scales at 1.15kg.
Both the MacBook Air and Series 9 are very fast and smooth running laptops. Of course they run two different platforms.
In like manner, the gigantic, catch-less, glass touch pads both of the proposed laptops wear are extraordinarily comparative in utilization, with the vast majority of the distinction being down to drivers and product.
Hi There,
Samsung's 900X3B and MacBook Air laptops are very thin light weight devices, but the thinner one is the Samsung Series 9. The MacBook Air 13in brandishes a most extreme thickness of 17mm, but Samsung's 900X3B takes slenderness to unique levels, measuring an insignificant 12.9mm at its bulkiest finish.
When it approaches weight the Series 9 wins, as it beats the Air's 1.35kg by tipping the scales at 1.15kg.Both the MacBook Air and Series 9 are very fast and smooth running laptops.
Of course they run two different platforms. In like manner, the gigantic, clutch-less, glass touch pads both of the proposed laptops wear are extraordinarily comparative in utilization, with the vast majority of the distinction being down to drivers and product.
Regards.
