black.boss
Posted on - 10/25/2011
I have a Samsung LCD monitor which I bought about 2 years ago.
Now the monitor's display shows some disturbance. Some water like wave flow smoothly on the screen. Long term shutdown of the monitor slightly solve it but occurs again when long term running.
Please give me a solution.
Samsung LCD monitor display problem .
Hi Black Boss,
   Does anything happened to your lcd monitor.  Might as well you drop it or bang.  The wavelike
form in the display monitor is a sign the liquid crystal inside it  is damage already or maybe
erupted due to the dropping of the monitor. Â LCD repair is avery expensive thing to repair. Better
to just buy a new LCD.
Hope this might helpou.
Thanks,
Michael21
Hello Black boss,
The problem may have been caused by some damage to your LCD screen such as falling or it got a knock. The problem can be fixed by carefuly opening the LCD screen yourself or an expert and check the cable connections. One or more cables maybe loose or some other damage occurred inside the LCD screen. The best option will be to know what exactly is damaged inside the screen and then try it repaired or replace the LCD screen.
Thank you.
