Samsung New PC Studio Tool
I heard something really nice about this new Samsung PC studio Tool. Because it can connect everything stored in phone with computer or laptop.Does it has a limitation on what phone or device are suited for this New PC Studio tool by Samsung?
Answered By 0 points N/A #135242
Yes. This new tool is really nice. The PC Studio tool allows synchronization of phone book, messages and other phone applications. This will keep you mobile phone updated and managed at all times with minimum effort.
The new Samsung PC Studio tool is not compatible with all mobile phones. Some features and functions may not even apply to all models. This is specifically built for a particular device. You can check if your device is supported on the Samsung's support site.
This tool is not even compatible with Macintosh.
You can connect some devices with the new PC Studio however, they may not be able to use some of the features within the application. They vary by mobile phone model and New PC Studio version so you still have to check.
