Samsung NX210 wifi camera ?
Is it true that Samsung's NX210 is the first camera which has WiFi connection and interchangeable lens facility.
What difference it will make from others.
I want to know what it is capable of.
Yes it is true that Samsung NX210 is designed with WiFi mode. It allows you to directly save photos and videos to your computer; you can also e-mail it directly or upload it to your social networks.
No need to bring your card reader or cable anywhere so you can transfer or save your photos.
You can also use your smartphone to remotely control Samsung NX210.
Samsung improves its appearance by having all metal body that gives classy looks to its external view.
Its features:
In addition, NX210 can shoot stills up to 8 frames per seconds and can capture 1080p30 with control over shutter speed and aperture.Â
The Features of this Camera Include;
It is different from the previous versions in that;
Its Capabilities;
WIFI Connectivity allows sharing of images wirelessly, transfer them to a smartphone, or use a smartphone to remote-control camera.
