Samsung’s Series 5 hybrid PC enquiry
I want to know what are hybrid PCs and the difference between a normal PC (desktop/laptop) and a Hybrid PC? I would also like to know what are the features of the Samsung Series 5 hybrid PC? What does those series means?
Answered By 0 points N/A #160278
Hybrid computers are computers that will accept analog signals and transform those signals to digital and process it as digital. Computers that can do that is called Hybrid computers. A computer that has a touch screen capability is a good example of a hybrid computer.
Normal computers on the other hand are like the computers that we have before. A CRT screen computer is a good example for a normal computer.
Samsung Series 5 Hybrid has these features:
  • A detachable keyboard so you can use it as a tablet or a laptop.
  • Series 5 has 10 hrs battery life and a pair of 2 and 8 megapixel cameras.
  • Supports pen input that came with the device.
For your last question about series, example: series 1, 2, 3, 4. It is called series because they share the same specifications but differ of the modifications of the previous device.
Hope you will find this helpful.
Cheers.
