I got this Samsung Galaxy S4 last week and today I noticed that the silvery coating is coming off on the corners, I have not dropped or scratched the phone, also my battery is leaking from one side, what could be the problem with this phone? How do I get another battery for Samsung Galaxy S4?
It is not recommended to turn on your phone Samsung Galaxy S4 if the battery started to leak. Also is not recommended for you to start to repair it in any some way because you can break it more. If you still have a warranty certificate to your phone go at the shop where your phone was bought and they will give to you a new one battery and will fix the silvery coating. If any of those cannot be repaired they will give you a new phone. Also if you don't have the warranty certificate go to an authorized dealer and buy a new battery and also you can fix the silvery coating.
You have these problems with your phone because it might be possible that you bought a phone that was weak from the factory, the problems with battery at Samsung Galaxy S4 are a common problem for many users.
If your phone’s battery is leaking, stop using it because it could explode like what I saw in the news. Your phone’s battery is removable so there’s no problem replacing it with a new one. Buy a new battery from a local store like in the mall and buy a battery specific to your phone.
Don’t buy or use a battery from another phone model even if it fits because it could damage your device. Here are your phone’s specs. The Samsung Galaxy S4 I9500 is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies.
It was announced to the public on March 2013 and released on April 2013 measuring 136.6 x 69.8 x 7.9 millimeters and weighing 130 grams. It is built with plastic body and uses micro-SIM card. It has Super AMOLED capacitive touchscreen display with 16M colors at 1080 x 1920 pixels screen resolution protected with Corning Gorilla Glass 3.
It ships with Android 4.2.2 Jelly Bean upgradable to Android 5.0.1 Lollipop with TouchWiz UI powered by 28 nm Exynos 5410 Octa chipset, Octa-Core processor (4 x 1.6 GHz Cortex-A15 and 4 x 1.2 GHz Cortex-A7), and PowerVR SGX544MP3 GPU. It supports microSD expandable up to 64 GB. It runs on 2 GB RAM with internal storage available in 16 GB, 32 GB, and 64 GB capacities.
The primary camera supports 13 megapixels with f/2.2, 31mm (standard), 1/3″, 1.14µm, and AF featuring HDR and LED flash. It can record video in 1080p at 30 fps with dual-video rec. The secondary camera supports 2 megapixels with f/2.4 and 31mm (standard) featuring dual video call. It can record video in 1080p at 30 fps.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP, EDR, LE, and aptX support; GPS with A-GPS and GLONASS support; NFC; infrared; and microUSB 2.0 with MHL 2 TV-out and USB Host support.
It has built-in accelerometer, gyro, proximity, compass, barometer, temperature, humidity, and gesture sensors: ANT+, S-Voice natural language commands and dictation, and air gestures. It runs on removable Li-Ion 2600 mAh battery with standby time up to 370 hours on 3G and talk time up to 17 hours on 3G. It is available in White Frost, Black Mist, Arctic Blue, and Black Edition colors. It supports Qi wireless charging.
1....
