Brenda Lopez 20 points N/APosted on - 06/04/2015
I am planning to buy a new Samsung S6 mobile. But I have some queries regarding it.Does S6 Edge supports the full range of network spectrum, including 3G CDMA and 4G LTE? I am particularly concerned about its call quality and network speeds, whether it will be up to the mark or not. But I have heard that S6 Edge will give better download speed than iPhone, not sure about it. Should I buy S6 or should I go for IPhone 6? Please suggest.
1. Operating system in Samsung Galaxy S6 is Android 5.0 and in Apple iPhone 6 is iOS 8.
2. Screen Type in Samsung Galaxy S6 is Super AMOLED HD and in Apple iPhone 6 is IPS LCD.
3. Screen Pixels Per Inch in Samsung Galaxy S6 is 577 ppi and in Apple iPhone 6 is 326.
4. Screen Resolution in Samsung Galaxy S6 is 2560 x 1600 pixels and in Apple iPhone 6 is 1,334 by 750 pixels.
5. Camera Resolution in Samsung Galaxy S6 is 16MP Rear; 5MP Front-Facing and in Apple iPhone 6 is 8 MP Rear; 1.2 MP Front-Facing.
6. Video Camera Resolution in Samsung Galaxy S6 is 4K/1080P and in Apple iPhone 6 is 1080p.
7. Bluetooth Version in Samsung Galaxy S6 is 4.1 LE and in Apple iPhone 6 is 4.0 LE.
8. GPS and NFC are available in Samsung Galaxy S6 and in Apple iPhone 6.
9. Total Integrated Storage in Samsung Galaxy S6 is 32/64/128 GB and in Apple iPhone 6 is 32/64/128 GB.
10. Micro SD Slot Storage is not available in Samsung Galaxy S6 and in Apple iPhone 6.
11. S6 edge is highlighting in the device's camera, wireless charging, and curved display. S6 displays colors when your top five contacts call. The edge of the iPhone 6 displays nothing. But it has a vibrate
The Samsung Galaxy S6 edge is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was announced to the public on March 2015 and released on April 2015 measuring 142.1 x 70.1 x 7 millimeters and weighing 132 grams.
It is built with Corning Gorilla Glass 4 back panel and uses nano-SIM card with fingerprint sensor (PayPal certified) and Samsung Pay (Visa and MasterCard certified). It has super AMOLED capacitive touchscreen display with 16M colors at 1440 x 2560 pixels screen resolution. It supports multi-touch protected with Corning Gorilla Glass 4 with TouchWiz UI and curved edge screen.
It runs on Android 5.0.2 Lollipop upgradable to Android 5.1.1 Lollipop powered by Exynos 7420 chipset, 1.5 GHz Quad-Core Cortex-A53 and 2.1 GHz Quad-Core Cortex-A57 processors, and Mali-T760MP8 GPU. It doesn’t support microSD. It runs on 3 GB RAM with internal storage available in 32 GB, 64 GB, and 128 GB capacities.
The primary camera supports 16 megapixels at 2988 x 5312 pixels featuring LED flash, autofocus, optical image stabilization, geo-tagging, panorama, Auto HDR, face detection, and touch focus. It supports 2160p video recording at 30 fps, 1080p at 60 fps, and 720p at 120 fps with dual-video rec., and HDR.
The secondary camera supports 5 megapixels and 1440p video recording at 30 fps with Auto HDR and dual video call. It has Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, and hotspot support; Bluetooth 4.1 with A2DP, LE, and apt-X support; GPS with A-GPS, GLONASS, and Beidou support; NFC; and microUSB 2.0 with USB Host support. It has built-in accelerometer, gyro, proximity, heart rate, SpO2, compass, and barometer sensors.
The pre-installed web browser supports HTML5. It doesn’t support Java. It runs on non-removable Li-Ion 2600 mAh battery with talk time up to 18 hours on 3G. The Apple iPhone 6 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, CDMA, HSPA, EVDO, and LTE technologies.
iPhone 6
It was announced to the public and released on September 2014 measuring 138.1 x 67 x 6.9 millimeters and weighing 129 grams. It uses nano-SIM card built with aluminum body and front glass. It supports Apple Pay (Visa, MasterCard, and AMEX certified). It has LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 750 x 1334 pixels screen resolution.
It supports multi-touch protected with Ion-strengthened glass with oleophobic coating. It runs on iOS 8 upgradable to iOS 11.3 powered by Apple A8 chipset, 1.4 GHz Dual-Core Typhoon (ARM v8-based) processor, and PowerVR GX6450 (Quad-Core graphics) GPU. It doesn’t support microSD. It runs on 1 GB DDR3 RAM with internal storage available in 16 GB, 32 GB, 64 GB, and 128 GB capacities.
The primary camera supports 8 megapixels (f/2.2, 29mm, 1/3″, 1.5µm) featuring dual-LED dual-tone flash, phase detection autofocus, face and smile detection, touch focus, geo-tagging, and HDR (photo/panorama). It supports 1080p video recording at 60 fps and 720p at 240 fps. The secondary camera supports 1.2 megapixels (f/2.2, 31mm) and 720p video recording at 30 fps with face detection, HDR, and FaceTime over Wi-Fi or Cellular.
It has 3.5-millimeter jack with 16-bit/44.1kHz audio and active noise cancellation with dedicated mic, Wi-Fi 802.11 a/b/g/n/ac with dual-band and hotspot support, Bluetooth 4.0 with A2DP and LE support, GPS with A-GPS and GLONASS support, NFC (Apple Pay only), and proprietary USB 2.0 reversible connector. It doesn’t have stereo FM radio. It has built-in front-mounted fingerprint, accelerometer, gyro, proximity, compass, and barometer sensors.
The pre-installed Safari web browser supports HTML5. It runs on non-removable 6.9 Wh Li-Po 1810 mAh battery with standby time up to 250 hours on 3G and talk time up to 14 hours on 3G. It is available in space gray, silver, and gold colors.
1....
