Samsung S9 Have A Battery Problem
A year back I had a problem with my mobile phone, Samsung S9 which had a battery problem in it. My battery couldn’t even last for more than 5 hours. I used to charge my mobile phone for the whole night and then in the morning time I used to use it after 8 am and max to max it used to last till 1 pm.
Answered By 0 points N/A #318274
The main problem of the drainage of a mobile phone battery is because of some specific apps that we download. Might be of some use or some might be unnecessary. Sometimes there are some particular apps that tend to use much more battery.
To figure out the apps and locate it-
• Steps: – To know which app is using more battery, Go to the Play Store app and check the installed apps.
• If you can find these steps, go to the setting in your phone and then click the battery. Below apps will indicate which cause more battery drainage
• Follow the steps and kindly delete those apps.
