Is this Samsung Series 9 has similarity to Mac laptops?
As I was reviewing the specs of Samsung series notebook I notice some resemblance of Mac laptops, like aluminium body and others. Is this in similarity with Mac laptops?
Samsung is providing a wide range of notebooks and laptops. Most of the laptops will be having the same specs as others. Just look at the specs of Mac book it provides you good configuration processor of i5. Next, it provides 3 usb ports as other laptops do. If you are specifically focusing on body of the laptop then just look at the Samsung laptop body. Here each laptop vender may propose different kind of body to their laptops. Mac books have Mac os but the Samsung laptops are comfortable with any OS. That is the difference, and the clarity in Mac will be more compared to Samsung as the pixel resolution used in Mac books is of HD. So, never compare any laptop with others, because each have its own flaws and features.
An example of a series 9 Samsung laptop is the Samsung Series 9 15-inch (NP900X4B-A02US). It comes pre-installed with Microsoft Windows 7 Home Premium. It runs on Intel Core i5-2467M 1.6 GHz processor, 8 GB RAM, Intel HD Graphics 3000 graphics adapter, 128 GB SSD storage, Wi-Fi 802.11n, WiDi, two USB 3.0 ports, one USB 2.0 port, and Bluetooth.
It has a 15-inch display with 1600 x 900 widescreen resolution. It measures 0.6 x 14 x 9.3 inches and weighs 3.6 pounds. Standard battery rundown time is around 7 hours. For the pros, it is amazingly thin and light for a 15-inch laptop with bright high resolution display with WiDi support. For the cons, it has a shallow keyboard and slippery touchpad. It is also expensive.
Out of the 128 GB SSD storage, only 57 GB is available. Additionally, it doesn’t include HDMI and VGA dongles. It costs around $1,499.
