Samsung Star Mobile Free Antivirus
I want to load an antivirus for my mobile phone.Is this possible?
My mobile model is a Samsung Star 5230.
I am always on the web using my mobile and want to browse securely.
How will I go through this?
Is there a free antivirus for my Samsung mobile?
Best Answer by imtiaz
Answered By 0 points N/A #128949
this is good mobile cell phone. you have to use sis file accepted anti virus. Because this will be very protective and secure on your mobile. for your comment i understand that you wanted to browse Internet all time, so it is very essential to you using free anti virus. Remember free AntiVirus will never registered and your system may harm.
but the Samsung mobile care will very effective for your. There you get the real and original things about allof your you want. you will also get the free anti virus from below link: http://forum.gsmhosting.com/vbb/index.php/vbb/index.php
thanks.
Answered By 15 points N/A #128950
Hello Lanipam,
For sure you can load an antivirus on your phone, but then you have to download the antivirus application that can be used on a mobile phone. The normal antiviruses that you use on the computer cannot be usable on the mobile phone because it is big enough and cannot fit on the mobile phone's space.
So just Google on the internet for the right antivirus for your mobile phone.
Some of the antiviruses that I know that can be used on the phone include kaspersky and AVG. You can download them using a PC and then transfer them to the phone using a USB drive, or download them straight from the phone.
Regards
Clair Charles
