Samsung wave 723 reboot problem.
Hi techyv,
Samsung wave 723 reboot problem. I got this Samsung wave 723 mobile phone device with a Bada operating system, I think this is almost seven months old. It automatically reboots without asking my permission, while texting, making a call, playing mobile games and etc. Can you help me resolve this issue?
Hoping for your help and kind consideration.
Answered By 10 points N/A #185892
I will try my best to solve your issues. Try this Hold the menu button and power button together for 10 seconds. It will vibrate and reboot the mobile and fix the problem by itself in the reboot.
If the problem persists then Flash your mobile but do not do it yourself go to the service center of Samsung. If you try yourself and something goes wrong you will lose your mobile.
Answered By 590495 points N/A #315084
I also experience that problem with my phone but very rarely. Sometimes that problem is related to the battery especially if your battery is already old. But if you think the problem is not with the battery, the only thing you can do with your phone is to reset it or perform a hard reset to restore the device to its factory defaults.
To hard reset a Samsung Wave 723, first, make sure the phone is turned on. Next, enter the following code without quotes: “*2767*3855#”. After this, wait until the phone restarts and that’s it. See if this fixes the problem.
