Samsung Wave k on theme Bada OS
I have a Samsung S8500 Wave phone with Bada OS 2 installed on the phone. I'm looking for the first k themes for this phone. They should be as colorful as possible.
if your samsung has an samsung application icon click it and register its free if you are using wifi then you can browse there available items there for your phone including themes some of it where free and some have payments then you can download it and install it on your phone there are lots of themes to chose from or you can even use the internet search engine to search for themes then follow the instruction on how you will be able to download it on you phone you can also visit http://www.samsung.com/us/?redirectionId=http://apps.samsung.com/earth/main/getMain.as select your phone model then click themes and click how to get you can download it using your phone or samsung kies
