onam ophir
40 points
Posted on - 09/02/2012
Why can't I sync my contact to my Samsung wave from a parrot CLS 3200 hand free? It shows that it is syncing but the process is incessant. When I look at the address book after hours. It is still empty. Samsung wave parrot is showing problems.
Samsung wave parrot sync problems?
Hello Onam,
You might want to cancel the sync process and then restart it and see if it will be able to run successfully this time round. It may be just a temporary hang out that could be resolved when you restart the process. If the issue persists then you might need to troubleshoot for hardware as well as software problems.
Nicke
Try synching with your car kit. Let the wave search your Parrot via Bluetooth connection. There, try to download your contacts.
Or you can use the option of editing your sync method via your email account.
Follow these steps:
1. Go to the launcher
2. Then go to Social Accounts
3. Choose any email you want to use
4. You can see “Email sync”, “Calendar sync”, and “Contact sync”. To sync your contacts , green is yes and black is no.
