Sand boxie error to open the program due to missing dll files
I just installed Sandboxie on my PC and when I tried to open it this error appeared. Almost all the time when I install a new program on my PC I have this kind of error about missing DLL files. Is there anyone who can help me please to fix this error ? Why the DLL files missing from my PC ?
Thanks !
SbleCtrl.exe – Unable to Locate DLL
The dynamic link library gdiplus.dll could not be found in the specified pathC:ProgramFilsSandboxie;. C:WINNTSystem32;C:WINT;C:WINTsystem32;C:WINT’C:WINTsystem32Wbem;C:Program fileSamsungSamsung PC Studio 3.
Answered By 590495 points N/A #179061
I have bunch of applications installed on my computer and many of them have the file “gdiplus.dll” but different versions. Most of them are designed for the Service Pack 2 of my operating system and I also found several that are designed for Windows Vista which is not my operating system. In your case, if this issue happens most of the time when installing applications, I guess reinstalling them will do no good.
Check if the file is not missing and visible in “C:WINNTsystem32”. If the file is not missing in that location, I guess you need to register it again. Open Windows Explorer then navigate to “C:WINNTsystem32”. Verify that the file “gdiplus.dll” is viewable and accessible in the folder. If you verify that the file is not missing, register it again.
Click Start, Run then type without quotes “cmd” then hit Enter. In the command prompt, type without quotes “regsvr32 gdiplus.dll” then hit Enter. Restart the computer and see if your program works now. In case you can’t find the file inside “C:WINNTsystem32” folder, try searching drive C. Once found, copy it in “C:WINNTsystem32” then register it.
