Hi everyone! I had encountered a problem with sandboxie. I tried looking for other suggestions as I have received one from other forums but it didn’t resolve my problem.
When I try to download something on sandbox using firefox, I received this dllhost.exe error. This didn’t happen before I update it 3.48 64 bit. Also, I have restrictions when using it, only firefox can be able to start the program.
Do you have any idea how to solve my problem? Thank you!
Sandboxie dllhost.exe Error after update
Since you are already having problems using it, you should try doing a clean installation again. The application may already have some corrupted files that are causing this error on your program. Uninstall Sandboxie from your machine then restart your computer.
After booting the system, check your computer for any possible errors. Use a disk utility application to check the system. An error in the hard drive’s file system may also cause application problems.
After the disk check, install the application again. Try opening the program again after the installation.
If it still doesn’t work, you may try upgrading your current version of Sandboxie. If you are using an older version of the program, you can install Sandboxie 3.68.
This version was only released last April 10, 2012. You can visit https://www.sandboxie.com/DownloadSandboxie and then download this version from there.
