jaysonV
10 points
Posted on - 02/11/2012
When I run the SAP MMC, the condition of the server looks yellow and the work procedure status shows delay in WP-Table.
Also, an error occurred when I attempted to logon: “SAP Commit failed, session terminated”.
Want to get rid of this. Help needed.
Surujkb
SAP MMC server condition is yellow and logging in causes error
This may be for the connectivity of the internet server. Please follow the following steps 1 by 1 until the problem is solved.
1. Please remove/ off the internet connection for 1 to 2 minutes and reattach.
2. Please re-start the computer.
3. Please consult with your internet provider.
Hi there user:
This is a DTP failure. It’s rather an exception error on the system, the request was locked, or most probably Duplicate Records. I don’t see any option other than restarting the job.
But before you do it, you must delete the bad DTP request first.
Go to your information provider, click DTP step, and then ‘Update’ tab (to check the duplicate records). Click ‘Activate’ and then ‘Execute DTP’. And lastly, uncheck ‘Handle Duplicate’ records option. ‘Activate.’
Best regards,
