SAS System v.6.1. download error
Hey, I’m having trouble downloading the SAS System v. 6.1. I’ve already tried with the support but got no answer there and since the only options are to stop or exit the download (retry doesn’t work either) I have no idea how to fix this.
The error is this:
Download Interrupted
SAS has encountered an error downloading your order.
This is most likely the result of incorrect order information and can only be solved by contacting SAS Technical Support.
Refer to the Software Order E-mail for contact information.
Please Click “Retry” when SAS has corrected the problem,
Or “Stop Download and Exit” to terminate the Download Manager.
The download can be resumed when you restart the Download Manager.
I’ve already wasted enough time so please post any solutions you’ve got.
Thank you very much.
