Satellite A215-S7444 Automatically getting hybernate
My client's Toshiba Satellite A215-S7444, which I am currently working on, supposedly heated up one time and suddenly it just started to hibernate or go to sleep mode without being triggered to do so. The owner had his friend check it out by opening it up and from then the laptop wouldn't power ON anymore.
The battery and plug seems to be working fine as the LED light lights up indicating power. Obviously it's just the laptop itself that isn't working. Upon checking it myself, the wiring seems fine and couldn't determine any problem. Can anybody suggest what else I need to check or look for?
Would greatly appreciate your tips and advise.
Thank you.
