Satellite Internet vs Cable Internet which is better?
Which of the following are better for home businesses & which has the better internet connection?
Satellite internet vs Cable internet are 2 connections would like to know about
In remote areas satellite internet used. In far areas cable internet used.
Cable internet is a form of broadband internet. It is transferred by using coaxial television cables or fiber optics. Cable internet speeds 1.5Mbps to over 100Mbps. Cable internet speed depends on your service package. Cable internet is better than other. We can use multiple windows and programs at the same time without any interrupt. Cable internet customer service is good, but satellite internet is costly one. The cable internet service is very fast and also its plans are good. Cable internet is best for your home businesses and internet connection.Â
A Satellite Internet is a system where a satellite dish is used to send and receive internet information at the home location. This method of internet connection is used in those areas where the usual high-speed internet access, like cable and DSL, is not available. The technology is similar to that used for receiving satellite television and provides a high-speed internet connection.
The upload speed in a satellite internet is much slower compared to the standard 500 kbps. It is only around 50 kbps when doing an upload. But the download speed is much faster and is almost the speed as with a broadband connection. For more information about satellite internet, you may visit eHow tech | What Is Satellite Internet?
A Cable Internet is the type of internet service where your computer is connected to a network cable which is then connected to a modem and has direct access to your ISP or Internet Service Provider. It is also called a broadband internet. It is an internet service that runs off of the same network as cable television. For more information about cable internet, visit eHow tech | How Does Cable Internet Work?
