To Save Our Time In Finding And Replacing Each Word in 2010.
A Cameron 0 points N/APosted on - 09/26/2016
A word document is use to write reports, essays, poems, chapters etc. But if one word is spelled wrong, we will have to search the whole document and change each and every word. This is time consuming and irritating also. Word has an inbuilt feature of ‘find and replace’ to overcome this problem. How to find and replace in word 2010?
In Microsoft Office Word, no matter how long your document is, searching and replacing a particular word is easy using the “Find and Replace” feature. To do this, just finish composing your document. When everything is finished, press CTRL + F to bring up the search dialog. In the “Find and Replace” dialog, go to “Replace” tab and enter the search details.
Microsoft Office Word Find and Replace
In the “Find what” field, enter the word or incorrect word to search. In the “Replace with” field, enter the correct word or the correct spelling of the word then click “Find Next” to find the next instance of the word. Once a match is found, click either “Replace” or “Replace All”.
When you select “Replace”, you will only replace the current match and you have to click “Find Next” again to continue searching for matches. If you select “Replace All”, all instances of the matching word will be replaced at once.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
