I would like to add subtitles to a video and I don’t want to do it in Windows Live Movie Maker. I want to save this video with the subtitles on it in AVI so I can play it on my computer or burn in on a disk. Will I be able to save a video with subtitles in AVI using Aegisub?
Save a video with subtitles in AVI using Aegisub
Hi!
Here I would like to provide you with one solution to solve your problem.
This method is called Softsubbing.
1. Firstly, you should distribute the script files.
2. Then, you will need to provide the original subtitle files to the video.
3. Next, you should upload those subtitle files in player that capable of holding external subtitles.
4. Finally, you are done.
Hopefully, you can solve your problem. Otherwise, please seek help in here.
