Saved files of Pes2012 on win7
I have played with PES 2012 on Windows XP but now I upgraded operating system for Windows 7 and now my saved files didn’t work on Windows 7.
Please show me a way to solve this problem. Thank you
PES 2012 is compatible with Window 7. You should try to uninstall and re-install. Maybe there is a performance issue on your computer.
Make sure that your computer meets the system requirements of the game. Check for the system update on the developer's website, this might fix the compatibility issue.
There might be one of two reasons for which you can’t execute the saved files.
1. You did not back up all the system files and saved game of PES2012 on another drive except where Windows had to be upgraded to Windows 7. And you did not recover all the saved games to main directory after installing both Windows 7and PES2012.
2. The Windows 7 is more different than Windows XP. It may not support the files which once executed on Windows XP platform.
If none of the above is true then you should re-install the PES 2012.
With Best Regards
Shifflett Laurel
Notifications
