I am facing a problem in saving a document as ZOHO DOC. When I try to save it in my desired format, I get an error which says "internal server error". I simply don't understand what this error means. An error code also appears which 2201 is but I don't know what kind of an error is this?
Is anybody facing such a problem? If yes do let me know.
Looking forward to your replies
Thanks
JANE
Saving a document as ZOHO DOC
Hi Jane/Priscilla, sorry for the inconvenience, are you saving it in your hard drive? Just click on the export link on top and select a format, and save it in the specific location on your hard drive. Are you saving it in your ZOHO docs online? Just be sure to have internet connection although you can edit and access without connection because it will synchronized .Â
Click on upload option and click bulk upload from the menu. Select a folder to place a document on the left side.
If it does not help, see this link https://apihelp.wiki.zoho.com/savedocument.html
Is your document confidential? if not you can share it with [email protected].
Thanks for using ZOHO docs.
