Saving multiple account login in Remote Desktop
I have a work using Remote Desktop on Windows 7. I need to always login two accounts to open two accounts. I just want to know if is it possible to save two accounts so I don't need to login both accounts one by one?
Answered By 10 points N/A #119875
So you want to save remote desktop log in information. You can do this easily. Just check the box “Remember My Credential” before connecting a pc with remote desktop. You can do another thing. Go to network (For win7) or My Network Places (For XP). Then select the computer which you want to connect. Right click on it & select the option “Create Shortcut”. It will create shortcut to your desktop. Now go to desktop. You will get you desire PC. Right click on it & you will get the option “Connect with Remote Desktop” So you have the shortcut of connecting PC with Remote Desktop, which you wanted. Hope it was helpful
