Sbamui.exe – Application Error …
I use Windows Vista home edition.
After CPU runs for forty minutes machine goes to slow and the flowing message appear .at that time CPU seems very busy.
It happens almost every time that disrupts my every day jobs.
How can I resolved the problem?
  sbamui.exe – Application Error
               The instruction at 0x062a8fc7 referenced memory at 0x062a8fc7. The
               memory could not be read.
              Click on OK to terminate the program
Michel
Answered By 0 points N/A #92220
You might be experiencing a virus attack that run every forty minutes or something or the latest software that you have installed cause it.
Solution 1: Perform a scan through your whole operating system. It would detect a virus if there is, but remember to use a licensed anti virus software to solve this solution.
Solution 2: Restore your computer system to the point of the most previous date. Then start reinstalling the programs you installed before then check it one by one. To identify which software made this error.
Solution 3: You can simply remove it by reformatting your operating system but remember to backup first.
