Scan a negative by using my Canoscan 3000F
I keep on getting the following error message, whenever I try to scan a negative by using my Canoscan 3000F – I don't have the film guide for that scanner. I bought this second handed but could that be the problem?
ScanGear CS
Cannot scan for these reasons:
–         The original may not be set correctly.
–         The Film Adaptor Unit Protective Sheet may be put in place.
–         The lamp may be not warmed up.
(It needs a few minutes for adjusting lamp on low temperature.)
Scanner driver will be closed
Code: 2,181,10
