Scanner communication error with Hp Photosmart
Posted on - 09/24/2012
I am facing serious issues using the HP Photosmart software. I am using HP Office jet Pro A909g which is an AIO that supports network printing. However I have been unable to scan your my Windows 7 PC using the same. The error is displayed below:
A required software component was not found or was improperly installed. Reinstall the HP Photosmart software thatÂ
came with the device and try scanning again.
The software works for sometime after reinstallation and the problem crops up again and again.
Anyone worked with HP softwares before?
