I need help in finding the best scanner that can scan high quality images and still produce the same quality image as the original. Also, a scanner that can scan films will also be beneficial. Any scanner brands regardless of price will be accepted.
Scanner For High Quality Images and Scan Films
Nikon super cool scan 500 ED is high-performance dedicated film scanner designed for imaging professionals produce the same quality image as the original. with this scanner all your imaging problems will be solved.
Hi Jobert,
Your scanner may have a photo setting built into it, but if not, you need to set it at the highest possible resolution. That should make is as sharp as it's gonna get. Choosing the right scanner will depend on your priorities. If you have stacks of 35mm filmstrips that you want to digitize with a minimum amount of effort, the V350 is the better choice due to its easy-to-use built-in Auto Film Loader, which can scan 35mm filmstrips from two to six frames in length. For scanning 35mm slides, though, the 8600F is more productive because it can scan up to four slides at a time, while the V350 can handle only two. There are many companies which produce high quality scanner. I mention some of the company and give somewhere you found quality scanner-
You can visit here quality scanner. Canon scanner has a great offer .Canon
Canon lide -110
You can choose any of them here.
Another good quality scanner Epson.
Then it is your choice which you want to buy. I just help you to find some scanner.
