anonymous
7060 points
Posted on - 08/11/2011
I have recently bought a used scanner with 3 installation discs.
I installed it and it seems to be on my hard drive but when I click on the scanner icon, I get this error message, " THE SHELL 32.DLL FILE is linked to the missingexport SHLWAPI .DLL:SH REG US VALU A ".
What does this mean and how do I fix it?
Scanner installation error on hard drive
It mean that your installation is not fully completed and it keeps some errors in this case you can reinstall your scanner drivers and this time make sure you choose the settings that best for your device.
The other solution for this can be to install a new copy of drivers or install updated drivers for your drive you can search drivers from network then download them to your drive and then install them. But first make sure which kind of driver your device supports. Also if you can installed your major drivers then you can don't need to install the software for reorganizing the pictures and for editing them.
So you need to install the basic drivers and then you can just go to scan document using window scan or office document format. It will not only reduce your load on hard drive but will be more easier for you to scan document.
