Something Is Not Right Here Errors Uniden DMA Scanners. I am getting the below error message and looking for a solution. Please help me as soon as possible. Thanks in advance.
Error
This scanner is not an object for BCT15.
Rewriting is impossible.
Please turn off the power and remove the cable.
Hello JosephGAguilar,
This error can usually occur if the firmware you're trying to install is not the one you need for your model.
Please, double check and see if they match.
In case this is what caused your problem, simply download the right firmware update and you should be good to go.
If, however, the problem persists, you might want to check if you have deleted the old install files of the firmware update tool before installing a newer version. In this case you need to delete them, reinstall the tool and then try again.
Good luck!
