Schedule view crashes on Windows Vista
I recently downloaded and installed the free version of Schedule View 3.0 for my scheduling and calendar needs.  The program crashes when launched.  Is the program having compatibility issues with my OS?  I'm on Windows Vista 64 bit.  Thanks in advance.
Answered By 80 points N/A #159650
Hello Harford,
I understand the problem that you are facing. At this point of time try some basic troubleshooting steps like Uninstalling the Schedule view 3.0 from the system complete. Click on Start menu and run Control Panel -> Locate Schedule view 3.0 and click Change/ Remove to uninstall the program. Follow the uninstall wizard and uninstall the program. Once it is uninstall, reinstall it back again.
Thank you
