Schema extensions for config manager
Do I have the extend my schema for the config manager after upgrading it or after upgrading the AD domain or functional level of the forest?
If you upgrade AD domain or functional level of the forest then you must have extend of your schema for the configuration manager. To do this you have to config AD domain server and also with subnet mask. This is not a difficult work to do. You can so it simply by doing ADDS.
First install ADDS and then upgrade its forest or expend it. You will have more your schema for the configuration manager. You can use it to expend range for your network capability quota. If you have knowledge about ADDS then you can do it more quickly.
Notifications
