School Project – Flash made Korean Children Story
I just want to know if you have any knowledge or websites known to be my reference for my project in school.
I have to make a children story using Korean language.
I'm using flash by the way for making the said project.
I know there's a difference when it comes to literature by each country, I want to make a story as sensible as what Korea have.
Best Answer by James tasnu
Answered By 10 points N/A #154647
Hello Louis Loius
Sounds like a cool school project!!
Below is a link where you can find children stories which are made using flash and are very interesting.
I hope it will help you in your project.
http://jr.naver.com/story
You should also checkout the following link
http://www.jajucom.com/Story
Good Luck with your project
Answered By 0 points N/A #154648
Always keep the target audience in mind when creating stories. A good story equally spurs imagination and intellect, it flows naturally and has no plot holes. Children are very keen observers, so make sure that your characters and events are believable. Additionally, Koreans have a strong tendency in their culture to obey authority figures, therefore making a story where a child rebels is not likely to be accepted by Korean children.
