SCN at particular time (Oracle database)
Please can anybody tell me that how we can get SCN at a particular time of a database.?
Please advice.
Please advice.
System Change Number also known as SCN is an increasing number. It is an Oracle's clock, whenever a transaction is committed, it incremented.
However it is not possible to know the System Change Number that corresponds to the same transaction because the SCN is committed after the transaction.
I guess the best thing that you can do is get or grab the SCN immediately after you commit. In addition to that, a commit does not write data files and it does not update or control files. Moreover, flashblack can never recall any uncommitted work even you own.
I Hope this helps.
In database, SCN stands for System Change Number. It is the chief means of maintaining data regularity or consistency in Oracle database. Here are some of the areas where you can use SCN:
An SCN is composed of 2 components, the Base and the Wrap.
The Wrap component is a 16-bit number while the Base component is 32-bit.
Hello Techyv experts, as always your advise is genius and it goes without saying. So thanks, to both of you especially to Sharath for giving excellent performing answers. He is providing some areas in how to use and access SCN easily. Indeed, I am a complete layman about the areas where I can use SCN. After studying your free and easy comments I have achieved my desired information which I have mentioned in my question. Thanks from the core of my heart guys again as well also grateful to Techyv.com for giving space to post this.
