Frank Trask
10 points
Posted on - 05/10/2012
Hey all.
How can I install Scrapbook Deluxe 5.0 successfully on my computer? I had the problem at the end of the installation where an error would appear saying "Error 1335. The cabinet Data 11.cab required for this installation is corrupt and can not be used. “ I should I fix this?
Scrapbook Deluxe 5: Error 1335 the cabinet data 11.cab is corrupt
Hi Frank,
The causes of 1335 errors are virus infection, poor memory maintenance, unclean Cd room, data, cab corruption, accidental registry changes. I will recommend you to close it and download from Mozilla Firefox or you can download with ie8 and disable download manager because the problem is not binary it is with the medium.
And do the standard method instead or if you prefer to do it manually, please check that your CD is clean, because dust and scratches can prevent the download. Check also the memory settings of your computer, because installation has memory requirement, temporarily disable anti-virus because it can disrupt the installation process. Install the media now by different CD room and it's driver or driver's controller or create another install point on network.
