Devinuhler
Posted on - 05/10/2012
Hey, I have Scrapbook Factory Version 5 disc that I want to install in my laptop. When I tried to install it, the disk just spins. My OS is Windows 7. Could the product be not compatible with my laptop? Please give me some answers. Thank you.
Scrapbook factory 5 Disk does not launch
Hy
Scrapbook Factory Version 5 is compatible in your current operating system windows seven. So there have no any reason to get error to install it in your computer. Actually you got error for the problem of your Scrapbook Factory Version 5 disk. This disk is corrupt or file missing for burn problem. So you cannot fix the disk problem now. You should change the disk for resolve that issue.
Your Scrapbook Factory Version 5 disk spins in your DVD ROM for the problem of that disk. So just go to the CD library and then buy a new one for install that software in your computer.
If you want, you can download Scrapbook Factory Version 5 form internet too.
Hope your problem will resolve.
Thanks
