Scrapbook factory Windows Installer problem
I successfully installed Scrapbook Factory Deluxe version 5 on my computer. However, when I clicked “finish” an error message appears. It states that "Windows installer service is unavailable. Another app may be running setup. Finish any installations in progress, or restart your computer and then rerun setup." There was no other program which running during the installation but I restarted the computer as directed. The error message still occurs. I uninstalled the program and installed it back again. There is still no change, error message keeps coming out. How do I fix this issue?
Answered By 5 points N/A #150700
Dear George Amash,
You are facing installation problem in your computer. Here are some tips for the solution of your problem.
Firstly, the problem can occur due to the old version of your software.
Secondly, your operating system having some problems, such virus affect, file missing etc.
For the solution you can follow the instruction below:
*Download the latest version of scrapbook factory deluxe.
* Try to install the software.
If the problem still remains,
* You need to update your operating system.
* Or you have to re-install your operating system.
* Then you try to install the software.
I think your problem will be solved.
Thank you.
