Screen Blinks when PowerPoint Presentation runs on Multiple Monitor Setup
While trying to use PowerPoint (Office 2010) on a multiple monitor setup, the screen starts blinking and the computer locks. After using task manager to close it and then remove the multiple monitors, it works perfectly. Did anyone else encounter the same problem? Do you think that by installing a new printer driver and reducing the graphics acceleration will the problem disappear?
