Screen Flash out by pressing Ctrl+Alt+Del after Hang:
Sometimes my system got hang, I do press Ctrl+Alt+Del for closing the Applications but after close that, my desktop icons and Windows Menu Bar Disappear. How do I flash back my Desktop again. Kindly help me with this.
Answered By 590495 points N/A #84161
If you are using the Windows Task Manager to close any hanging applications, be careful not to accidentally end other tasks that are running in the background. There is also another way of accessing the Windows Task Manager without using the dangerous CTRL + ALT + DEL shortcut. There is also another shortcut that is also used to access Windows Task Manager, by pressing CTRL + SHIFT + ESC keys. This shortcut is much safer than using the other one that can lead to accidentally restarting your computer.
If some of the desktop icons suddenly disappear including the menu bar, maybe you accidentally ended other tasks that are running in the background. If you are ending a task for the programs that are hanging, always go to the Applications tab to end a task. Never access the Processes tab unless it is necessary.
