Hi there,
I want to mirror my Samsung Galaxy note 10.1 2014 screen to my Samsung HDTV, I have tried Chrome cast and it's not working, I have checked the settings and everything looks okay, What other application can I use to mirror my screen? How can I mirror my screen without much problems?
Screen mirroring problem on Galaxy Note 10.1 2014
Hi !
To make a screen mirroring from your tablet Samsung Galaxy Note to your Samsung HDTV you can try to make a Wi-fi connection. To go Menu on your TV remote => go to Network => All Share Settings => go to Screen Mirroring. Your TV will start to search for connection. Also you will have to make the same settings on your Samsung Galaxy Note. When all settings are done they will connect automatically. Also you can try to screen mirroring with a software called Dongle Screen Mirroring.
You can make these connections you will have to make sure that your TV has a HDMI port with an wireless.
