Screen print in Windows 7 OS
Hi experts,
My keyboard's screen print option does not work in Win 7.
But I need to take some pictures from desktop.
What should I do?
Hi experts,
What should I do?
Hello Brayen,
If you are using wireless keyboard, I suggest you to check on the Function Lock key on your keyboard which might be stopping you from using the shortcut key.
If it doesn't help you try snipping tool to capture screen shots.
If your keyboard button does not work, then you can try On Screen Keyboard.
Place your OSK aside so it will not capture the keyboard.
My dear friend,
If you are using a wireless keyboard, you should check on it’s functions.
If that doesn’t help, you should visit this website.
Good luck.
You may have not noticed the ‘Snipping Tool’ option in Windows 7 OS.
Click on the window, then all programs and select accessories.
There you will get this option. Now click on the ‘New’ option and your desktop will be captured in image format.
You can select the full display or any portion from there.
