Hi experts,
I am using MAC OS X 10.1.4 and receiving an error message which effects the screen resolution. I don’t know how the error appeared. Please help me to solve this error and tell me the cause of this error.
Caution
The current
Screen
Screen Resolution error on Mac OS X 10.1.4
Hi Indira,
This is something that you won’t need to worry at all, if you have set your Macbook Pro on a resolution that is higher or lower than the optimum level which is 1920 x 1080, then you will get this message. However, your screen resolution is totally up to you it will be your own setting and you can customize whatever you want. If you get this prompt you just need to ignore it and click it away.
