Jayar31
Screen Resolution Error on my old HP DV6 PC
Here are the tips on how to troubleshoot and fix the laptop video problems is the screen of your laptop and you should be able to detect and eliminate basic laptop monitor problem. If you have a problem like this: .
The image appears above is the example by appearing a distorted with some horizontal lines running across the screen. I suggest to change your screen of your laptop because ones the screen is damaged, you can fix it but you have to ask the assistance for the technician.
Hope this is the solution to be able to solve your problem.
God Bless
Jay-Ar
You have to get a computer technician and have him check and measure the power output sent to the screen on initial start up. He has to adjust the settings to have the proper power output for the computer.
You can also have the technician check if your flex is defective. Because resolving this problem needs steps that can only be taken by an accredited Microsoft/Windows technician, or people who manufactured your computer themselves.
This is worrisome because it will have greater damage if not cured.
