Screen Rotated on my Windows XP
Asked By 220 points N/A Posted on -
Hi all,
When my brother's kids are playing a game in my Laptop, they accidentally pressed some keys. So now, the (Display)screen became upside down.
Could anybody help me to keep the screen display in the correct way?
Thanks
Best Answer by bobarikey
Answered By 0 points N/A #85907
Dear Mrihan,
So simple…. Press following keys together (ALT + CTRL + Up Arrow Key)
This is a feature in XP O/S you can rotate your screen by 360 Degrees. by pressing the following Key Combinations
To Normal Screen : (ALT + CTRL + Up Arrow Key)
Upside Down Screen: (ALT + CTRL + Down Arrow Key)
Left to Right Side Screen: (ALT + CTRL + Left Arrow Key)
Right to Left Side Screen: (ALT + CTRL + Right Arrow Key)
Thanks
Answered By 0 points N/A #85908
Please note that, some times the above key combination also work while the screen is locked
Answered By 220 points N/A #85909
Thanks buddy… it worked for me… 🙂
Answered By 200 points N/A #85910
You are welcome buddy.
I hope you could solve your problem.
Answered By 0 points N/A #85911
Our experts will always happy to help you. So do not hesitate to post any of your questions related to IT. Thanks
Answered By 0 points N/A #194823
Hi Dear,
When we install extreme graphic drivers on our computer, screen rotation options became enabled. You can turn your screen with key or mouse shortcuts.
Here are some shortcuts.
CTRL+ALT+Right Arrow.
CTRL+ALT+Left Arrow.
CTRL+ALT+Up Arrow.
CTRL+ALT+Down Arrow.
You have to press CTRL+ALT+Up Arrow to make your screen straight.
I hope this helps you.
