Screen Rotation Rectification
You can solve this problem in one of the two ways. I-You need to press the ‘alt, control, and upward arrow’ key together. You can find your screen and, II-you can right click and press the arrow keys to bring back to the normal screen.
If your screen has rotated by mistake, this can normally happen when you accidentally press the key combination or the shortcut key. The easiest way to restore your screen back to its original position is to press that key combination again. But if you don’t know how you did it, here are the shortcut keys for rotating the screen in different directions:
These shortcut keys or key combinations apply to all built-in Intel video cards or chipsets. To avoid accidentally rotating your screen again in the future, disable or uncheck “Hot Key Functionality” in your “Display” setting. You can find the “Display” setting in the Control Panel or click the “Display” icon on the system tray or notification area.
