Screen Saver turns off immediately after running
Robert,
There might be a problem with your monitor settings. It might be happening that when your screen saver starts, the monitor power is switched off automatically. Here are the steps to check that –
1. Go to Start.
2. Click Control Panel > Performance and Maintenance.
3. Go to Power Options.
4. Select the option Turn Off Monitor > Select After 1 hour or more from the dropdown menu.
5. Click Apply > Ok.
Now leave your computer idle for 10 min and the screen saver will run. You can also reduce the screen saver activation time from 10 min to 4-5 min.
If this doesn't work, then you can repair windows once from your installation CD. However, it looks like it is a settings problem.
